When copying a project, if a drawing is open within the project you wish to copy, the flow process should ask you whether you want to Quit or Save, Close & Continue. At the moment, if you have a drawing open that you are copying, you end up having to quit, closing the drawing and then repeating the process again. This change would be in addition to the following:
https://forums.autodesk.com/t5/autocad-electrical-ideas/improvement-for-copy-project-workflow/idi-p/...
Cheers
