XREF Attribute not populating properly
drew_dewit
Message 1 of 9
drew_dewit
We have an issue with our pressure switch symbols not updating properly after linking children. We have a child symbol we put in our pneumatic prints and link to a parent in our electrical prints. We don't use WDTAGALT as we want the same tag. Out pneumatic prints do not have line numbers but use a grid to number. After linking the child to the parent the XREF attribute only populates the sheet number. At this point the two blocks are linked properly as verified by the surfer and other attributes. I can force the XREF attribute to be correct with a cross-reference update. This all works fine if the child is on a sheet with line numbers but not a sheet using grids for numbering. Is this a bug in ACADE?
Replies (8)
Message 2 of 9
ramesh.kambang
I guess you have %N is missing in the  Cross-Reference Format, see marked in RED.
Ramesh Kambang
Aerospace System/Design Engineer and eVTOL/EWIS Expert
EASA 21J, UK 21J, MAA DAOS, Certification Specification CS23-29, CS-ANCS, CS-STAN and EVTOL
Please select "Accept Solution" if this post answers your question.
Message 3 of 9
drew_dewit
So that is the way the drawing is setup. Its like it doesn't recognize the X Zone values on the pneumatic page as %N values right away.
Message 4 of 9
ramesh.kambang
Are you using Reference numbers or X-Y Grid? If you post dwg file, will be helpful. I use X-Y works w/o problem.
Ramesh Kambang
Message 5 of 9
rhesusminus
As he wrote, He's using reference numbers for electrical schematics, and XY-grid for the penumatic drawings.
AS I understand, it doesn't reflect the grid once it's paired, but if you manually update the cross-references, it updates properly?
Might be a bug.. With an easy workaround.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 6 of 9
drew_dewit
@rhesusminusYou are correct that is what I am seeing
Message 7 of 9
drew_dewit
Is there a block required to hold the reference info similar to the WD_MLRHx blocks that the rung numbers use?
Message 8 of 9
drew_dewit
@ramesh.kambangwhat version of ACADE are you using?
Message 9 of 9
ramesh.kambang
I use both 2021 and 2018. In the screenshot below, schematic has line reference and panel drawing has x-y grid refs set. Both show sheet and references. This is not for parent and child but this should work for parent and child as well.
Ramesh Kambang
