AutoCAD Electrical Forum
Wrong wire numbers and references
6 REPLIES 6
HennyG
319 Views, 6 Replies
After Update/Retag project wide cross references and wire numbers, the wire numbers changed into "?6"
And references are incomplete. Only sheet number without x zone reference.
If I check with Surf for the cross references, there is only Sheet vissible, without Reference.
6 REPLIES 6
rhesusminus
in reply to: HennyG
If you number by page instead of project wide, will it work then?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
HennyG
in reply to: rhesusminus
No, drawing wide, same result
rhesusminus
in reply to: HennyG
Some screenshots might be helpful. Your Wire Number settings etc.
Trond Hasse Lie
Ctrl Alt El
HennyG
Attached my settings and result.
Is this the information you asked for?
rhesusminus
in reply to: HennyG
If you run the same commands on one of the demo projects that comes with AutoCAD Electrical, will it work in those projects?
It's difficult to troubleshoot without seeing the actual project, so let's find out if it's project related or not first.
Trond Hasse Lie
Ctrl Alt El
HennyG
For other projects the references and wire number generating is  going well.
