Forums
Architecture, Engineering & Construction Community Hub
Back
Architecture, Engineering & Construction Hub
See all
Product Design & Manufacturing Community Hub
Back
Product Design & Manufacturing Hub
See all
Media & Entertainment Community Hub
Back
Media & Entertainment Hub
See all
Community Hub
Back
Community Hub
See all
Subscription, Installation & Licensing
All Forums
Blog
Events
Groups
Gallery
Autodesk University
Forums
See all
See all
See all
Community Hub
Community Hub
See all
All Forums
Blog
Events
Groups
Gallery
Autodesk University
Home
AutoCAD Electrical Forums
All community
This section
This board
Knowledge base
Users
Products
Turn on suggestions
Show
only
Search instead for
Welcome to the Autodesk AutoCAD Electrical Forum. Ask questions, share your knowledge, and make connections.
Autodesk for small business
Design & Make software that works as hard as your business.
Explore today
Activity feed
Communities by language
Ask a question, share your knowledge, or submit a product idea.
Start a topic
Options
Mark all as New
Mark all as Read
Float this item to the top
Subscribe
Bookmark
Subscribe to RSS Feed
Sort by Topic Start Date
All
Trending
Accepted solutions
Unanswered
Most Viewed
Latest
Oldest
New to the AutoCAD Electrical Forum?
Start Here
Community managers
CGBenner
AutoCAD Electrical Forums ideas
Share ideas for improving Autodesk products with the team that makes it and submit requests for the features that you would like to see.
Explore ideas
Related tags
"Animation"
(1)
"AutoCAD 2025"
(4)
"AUTOCAD LT 2026"
(1)
"autocad-electrical"
(1)
"Automation"
(1)
"Bug"
(1)
"Command Input"
(1)
"custom attributes"
(1)
"custom-installer"
(1)
"Electrical"
(1)
"model"
(1)
"PDF"
(2)
"Plotting"
(1)
"Publish"
(1)
"Sub Assembly"
(1)
"symbol"
(1)
'Find'
(1)
-BLOCK
(1)
.dat
(1)
.dwg
(1)
.dwt
(1)
.env
(1)
.lsp
(1)
.net
(1)
.NET API
(3)
.scr
(1)
.WDL files
(1)
2-Pole Fused Switch
(1)
2020
(1)
2021
(2)
2021 AutoCAD
(1)
2023
(1)
2023 AutoCAD electrical - wire number
(2)
2023 AutoCAD LT
(1)
2024 AutoCAD electrical
(1)
2024 AutoCAD electrical - wire number leader loop size problem
(1)
2025
(1)
315A IEC60617 NFPA missing in the full version of Autocad electrical 2021
(1)
3D Model Download
(1)
@AutoLISP
(2)
A 2026 installation
(1)
A0 Template
(1)
Acad
(1)
ACADE
(13)
ACADE - Catalog Lookup
(3)
ACADE Crashin on opening an additional instance.
(1)
acade start tab crashes
(1)
ACADE2018 Wire Numbering
(1)
ACADE2025 Sub QTY
(1)
ACADE2026
(1)
ACC
(1)
access
(1)
ACE electrical audit
(1)
action
(1)
Activation
(1)
add attribute
(2)
Add-ins
(1)
adding attribute
(1)
adjust dialog box
(1)
ADS request error
(1)
Advertisement
(1)
AEC
(1)
AECATALOG
(2)
Alerts
(1)
All Caps
(1)
Analog Signals
(1)
Annotation
(1)
Annotative
(1)
Annotative Scale
(1)
API
(3)
API | Customization
(2)
Arrowhead
(1)
Assemblies
(1)
assembly code
(1)
assembly list
(1)
attribute
(1)
Attribute definitions
(1)
Attribute Editor
(1)
attribute fields
(1)
attributes
(12)
attributes error
(1)
Authenticator App Failure
(1)
auto-complete
(1)
autocad
(23)
AutoCAD .NET
(2)
autocad 2021
(2)
AutoCAD 2025
(1)
AutoCAD and OneDrive troubleshooting
(1)
AutoCAD API
(1)
AutoCAD Application
(1)
AutoCAD deployment on Azure
(1)
Autocad Elecrtrical
(1)
AutoCAD Electrical
(81)
Autocad electrical "report generation"
(1)
AutoCAD Electrical 2018
(2)
AutoCAD Electrical 2020
(1)
AutoCAD Electrical 2021
(1)
AutoCAD Electrical 2022
(6)
autocad electrical 2023
(7)
Autocad Electrical 2024
(2)
(4)
AutoCAD Electrical to Inventor API
(1)
AutoCAD error
(1)
Autocad integration
(1)
AutoCAD MEP 2020 Electrical
(1)
AutoCAD Titleblocks
(1)
AutoCAD Toolsets
(1)
AutoCAD2018
(1)
autocadelectrical
(3)
AutoCADElectrical2023
(2)
AutodCAD Electrical
(1)
Autodesk Construction Cloud
(1)
Autodesk Vault
(1)
Autolisp
(11)
AutoLISP and General Customization
(3)
Automatic insertion
(2)
Automatic Numbering
(1)
Automatic Save
(1)
Automation
(3)
aux contacs
(1)
bad argument value
(1)
balloon
(1)
balloons
(1)
batch
(1)
BATTMAN
(1)
Bill of Materials
(3)
block
(2)
Block Attributes
(3)
block edit
(1)
block editor
(3)
Block Issues
(1)
BLOCKCREATEMODE
(1)
blocks
(4)
blockswap
(1)
BOM
(12)
BOM Description
(1)
BOM on drawing
(1)
BOM Report
(1)
BOMs
(1)
break
(1)
Break Out Associations
(1)
bug
(1)
bug report
(1)
Bug Reports
(1)
Bugs
(1)
bus tap
(1)
C-sharp
(1)
cabinet
(1)
cable
(1)
Cable Connector
(1)
Cable Design
(2)
Cable Label Report
(1)
Cable Markers
(1)
cable quantity
(1)
Cable Report
(1)
cable tofrom report
(1)
Cable Tray
(1)
CAD Managment
(1)
CAD Symbols
(2)
can't change appearance
(1)
cannot find component
(1)
Catalog
(12)
catalog browser
(1)
Catalog data
(2)
catalog database
(1)
catalog database error
(1)
catalog editor
(1)
Catalogue
(1)
CERTIFICATIONS
(1)
child
(2)
child contact
(1)
Circuit
(1)
Circuit builder
(2)
clipping boundary
(2)
close wire and finish connection
(1)
Cloud
(1)
Cloud Files
(1)
CLSID
(1)
code
(1)
collectively add attributes to a library of symbols.
(1)
Color
(1)
COM
(1)
Company Implementation
(1)
component
(6)
component attribute
(1)
Component Retag
(2)
Component spacing
(1)
Component Tags
(1)
components
(7)
conduit
(1)
connection point
(1)
connections
(1)
Connector
(5)
Connector Detail
(1)
Connectors
(8)
Construction Cloud
(1)
Contact
(1)
contact tag suffix
(1)
contactor
(1)
Contacts
(2)
Content
(7)
Content Center
(1)
Content database
(1)
control systems
(1)
controls
(1)
coordinates
(1)
coordinates of symbols
(1)
Copy
(1)
copying a project
(1)
corruption
(1)
Create Project
(1)
Cross reference
(2)
Cross References
(3)
Cross referrencing
(1)
Cross-references
(2)
Cross-referencing
(1)
csharp
(1)
CUI
(1)
custom
(3)
Custom catalog
(1)
Custom Component
(1)
Custom Environments
(1)
Custom Objects
(1)
Custom PLC
(1)
custom ribbon
(1)
Custom Schematic Symbols
(1)
Custom Scripting
(1)
Custom sub assembly
(1)
Custom Symbol
(2)
Custom Symbols
(2)
Custom Terminal Foot print
(2)
Custom Title Block
(2)
Customization
(3)
Customize Electrical Symbol
(2)
Customize PLC Symbol
(1)
Customize User Interface
(1)
dashed line
(1)
Data Link
(1)
database
(4)
DataBase Editor
(2)
Databases
(1)
DB
(1)
DCL
(1)
Default settings
(2)
default_cat.mdb
(1)
Description
(1)
descriptions
(2)
Design
(1)
Destination Arrow
(1)
Diagrams
(1)
dialog box
(1)
difficult
(1)
dimensions
(1)
DIN
(2)
DIN Rail
(2)
display view
(1)
Distribution Block
(1)
dll
(2)
Drawing description
(1)
drawing properties
(2)
drawing rungs field
(1)
Drawing Symbols
(1)
drawing template
(1)
Drawing templates
(1)
Drawings Properties]
(1)
dropbox
(1)
Duct
(1)
duplicate
(1)
Duplicate numbers
(1)
DWG to PDF
(1)
dynamic block
(1)
dynamic blocks
(3)
dynamic blocks forum
(2)
Dynamic Input
(1)
Dynamic Symbols
(1)
EAGLE
(1)
Earth bar creation
(1)
edit
(2)
edit attributes
(1)
Edit Component
(2)
edit wire number
(1)
editing attributes
(1)
Educational account
(1)
elecdes
(1)
ELECTICAL
(1)
ELECTR
(1)
Electrical
(36)
electrical 2021
(1)
electrical drawing in autocad
(4)
ELECTRICAL DRAWINGS
(1)
Electrical engineering
(1)
Electrical Toolset
(1)
electrical2025
(1)
Enviroment Variables
(1)
environment file
(1)
Environment Variables
(2)
eplan
(1)
Error
(4)
error fail to start
(1)
Error message
(1)
Excel
(2)
Excel Report
(1)
Export
(2)
export data from symbols
(1)
export reports
(1)
exporting
(1)
External references
(1)
Extract Data
(1)
failed
(1)
failure
(1)
Fan In Source
(1)
Fan Out Destination
(1)
favorites file loc
(1)
Field Codes
(1)
Fields
(1)
File location
(1)
Files
(1)
Find
(1)
Fluid Power
(1)
font size
(2)
fonts
(1)
footprint
(6)
Footprint Lookup
(1)
Footprints
(2)
foreground
(1)
format
(1)
formatting
(1)
FOUND
(1)
freeze
(1)
From
(1)
From-To Reports
(2)
from_to
(1)
Fused Distribution Blocks
(1)
Fusion Lifecycle
(1)
General
(1)
Generating of List of used Relay contacts on Wiring diagram
(1)
GetBoundingBox
(1)
Getting Started
(2)
Group by
(1)
Help
(5)
Help & Learning
(1)
HELP PLEASE
(1)
Hide - Unhide
(1)
hotkeys
(1)
How to
(2)
hyperlink
(1)
Hyperlinks
(2)
Hyphen
(1)
Icon
(1)
Icon Menu
(4)
Icon Menu IEC-60617
(1)
Icon Menu Wizard
(2)
icon size
(1)
iconmenu
(1)
icons
(1)
IEC 3-postion swtich
(1)
IEEE 315
(1)
Images
(1)
images do not crop
(1)
import blocks
(1)
Import Export Data
(1)
Importing Data
(1)
in AutoCAD Electyr
(1)
Innovation
(1)
inserting icons from wizard
(1)
Insertion
(1)
Installation
(1)
Installing autocad electrical
(1)
instrumentation
(1)
Internal PartNumbers
(1)
invalid file name
(1)
Inventor 2022
(1)
Issue
(1)
Issues
(1)
Item Number
(1)
Item Number Balloons
(2)
item numbers
(1)
Items & BOMs
(1)
jumper
(1)
ladder
(2)
Ladder Diagram
(1)
ladder drawing styles used
(1)
lag
(1)
laggy
(1)
landing page
(1)
Language conversion
(1)
Layer Color
(1)
Layers
(3)
layers component
(1)
Layout
(2)
lentityp confusing me
(1)
Libraries
(1)
library symbol
(1)
line weights
(1)
Link
(1)
link components
(2)
link line
(1)
Link to CAD models from PDF
(1)
Linked
(1)
Lisp
(4)
Lisp routine
(1)
Lisp routine help
(1)
lisp routines
(1)
lisp support
(1)
list
(1)
Location
(2)
Location Code
(1)
Location View
(1)
LOGIN ERROR
(1)
Macro
(1)
mating
(1)
Mechanical Design
(1)
Meetup
(1)
menu
(1)
Menus
(1)
Microsoft Access
(1)
Missing
(1)
missing data
(1)
mode
(1)
Modify default tag
(1)
move
(1)
moving
(1)
Mtext Issues
(1)
multi-level terminal blocks
(1)
Multi-Page
(1)
Multiple Bus
(1)
multiple drawings
(1)
multiple parts
(1)
nameplate
(1)
NCHole
(1)
Network drive
(1)
networking
(1)
new install
(1)
New project
(1)
Non-default symbol layer
(1)
not
(1)
not inserting
(1)
object snaps
(1)
ObjectARX
(1)
Odd symbol
(1)
One-line
(1)
open
(1)
opening drawings
(1)
or previewed
(1)
orientation
(1)
Ortho Mode
(1)
Overlays
(1)
P&ID
(1)
panel
(3)
Panel layout
(8)
Panels
(2)
paper size
(1)
parametric
(1)
Parametric PLC
(2)
parent
(2)
PARENT ADN CHILD
(1)
parent child
(3)
Path display
(1)
Paths
(1)
PCB
(1)
PCB Design
(1)
PDF
(4)
PDF Print
(1)
PDF problem
(1)
PDM
(1)
PEER-TO-PEER
(1)
PIN LIST
(1)
Pin Lists
(1)
PINLIST
(1)
PINLIST HElp
(1)
Pins
(1)
Placed
(1)
PLC
(8)
PLC Cad
(1)
PLC database
(1)
PLC Editor
(4)
PLC Modules
(3)
PLC parametric selection
(1)
PLCIO
(2)
Plot and Publish
(1)
plot thickness
(1)
plot transparency
(1)
Plotting
(2)
plugins
(1)
Pneumatic
(1)
Pneumatic Components
(1)
Polygon
(2)
Post-Processing
(1)
printing
(1)
problem
(1)
productivity
(1)
profile
(3)
Profiles
(1)
Project
(2)
Project browser
(1)
Project Creation
(1)
Project Explorer
(1)
Project Files
(2)
Project Management
(1)
Project Manager
(7)
project-wide
(1)
Publish
(1)
Purchase List
(1)
quick access toolbar
(1)
Raster Images
(1)
rdf file
(1)
reference
(1)
referencing
(1)
Relay
(2)
relay contacts
(1)
remote desktop
(1)
Remote work
(1)
replace
(1)
Replication
(1)
report
(2)
Report Creator
(1)
Report Generation
(2)
Report Generation Issue
(1)
Reporting
(3)
Reports
(15)
Reports - Cable Labels
(1)
retag
(1)
RETAIN
(1)
Revision
(2)
right click
(1)
rolling sphere method lightning protection
(1)
Route
(1)
RSLogix 500
(1)
same
(1)
Saved Circuits
(2)
scale
(2)
Scaling
(1)
scaling issues
(1)
Schematic
(7)
Schematic help
(1)
schematic ladder
(1)
Schematic List
(1)
Schematic Symbols
(3)
Schematic Terminals
(4)
schematic toolbar
(1)
schematics
(1)
script
(3)
Scripting
(1)
scripts
(3)
SDK
(1)
set files
(1)
setup title block
(1)
Shared Libraries
(1)
sheet set manager
(2)
sheet wire number
(1)
shielded cables
(1)
Shortcut Menu
(1)
shortcuts
(1)
Show feet and inches
(1)
Siemens
(2)
Signal Arrow
(2)
Signal Tag Retag
(1)
SLD
(1)
slow
(2)
Slow Performance
(1)
Smart PDF's
(1)
SolidWorks add-in
(1)
Source and Destination Arrows
(5)
Source Destination Arrows
(1)
Specification
(1)
Split Tags
(1)
SQL
(2)
SQL Access Database
(1)
ssm
(2)
startup
(2)
startup failure
(1)
sub assembly
(1)
Support
(1)
Surf
(1)
Surf Dialog Box
(1)
surfer
(1)
swap
(1)
Swap Part
(1)
Swap title block
(1)
Switch
(1)
symbol
(5)
symbol attribute
(2)
symbol audit
(1)
Symbol Builder
(8)
symbol family type
(1)
Symbol Library
(4)
symbol shape
(1)
symbolbuilder
(1)
symbols
(6)
SYMS
(1)
table
(1)
table formatting issue
(1)
Tables
(2)
TAG
(1)
TAG Rename
(1)
Tagging
(4)
TagNumber
(1)
tags
(3)
taskbar
(1)
team collaboration
(1)
Technical difficulty
(2)
Template
(4)
Templates
(1)
term
(1)
terminal
(4)
terminal block
(4)
terminal block properties
(1)
Terminal blocks
(2)
Terminal Foot print
(4)
Terminal jumper
(1)
Terminal number
(3)
Terminal Strip
(12)
Terminal Strip Editor
(4)
terminals
(5)
Termination drawing
(1)
Terminations
(1)
text height
(1)
TEXT STYLE
(3)
TEXT STYLE ERRORS
(1)
Tips and Tricks
(1)
title block
(6)
Title block editing
(2)
title block setup
(3)
Title Block Update
(2)
title blocks
(1)
Titleblock
(3)
Titleblock Swapping
(1)
titleblock update
(2)
to
(1)
Toggle insertion of part
(1)
toggle wdtype
(1)
Toolbar
(1)
Tools
(1)
Training | Tips & Tricks
(1)
trouble
(1)
troubleshooting
(2)
TSE
(4)
unresponsive
(1)
update
(4)
Update-Service Packs
(1)
Updates
(9)
Updating PLC Database file
(1)
Upgrade
(1)
upgrading 2019 2025
(1)
Upgrading Attributes
(1)
useless
(1)
User Columns
(1)
User experience
(1)
User Profile
(1)
user1
(1)
user2
(1)
Utilities
(1)
Vault
(2)
Vault Workgroup
(1)
VBA
(2)
View
(1)
viewing issues
(1)
visibility
(1)
Visibility states
(1)
wd.env
(6)
wd_env
(2)
WD_PMENU
(1)
wddot
(1)
WDTYPE
(1)
Webinar
(1)
wildcard characters
(1)
Wildcards
(1)
WIPEOUT
(1)
wire
(4)
Wire Annotation
(4)
wire edit attribute
(1)
Wire from to
(1)
wire grouping
(1)
wire label
(1)
Wire Label Report
(2)
wire length
(1)
Wire names
(1)
wire number
(3)
Wire Numbering
(15)
Wire Numbers
(3)
WireList
(2)
WIRENO
(1)
WIRENO TERM Footprint
(2)
Wires
(5)
Wireway
(1)
wiring
(3)
Wiring Diagram
(1)
Wiring Style Option
(1)
Workflow Improvement
(1)
XDATA
(1)
xref
(3)
xrefs
(1)
zoom
(1)
Previous
Next
Event
What's new in AutoCAD 2027
Apr 16, 2026
8:00 AM US/Pacific
See all events
Top contributors
User
Count
rhesusminus
3
jaya_priya_rama
samy
1
arshdeepsingh40
4
1
View All
Trending topics and solutions
Blog
Managing the Project Database in AutoCAD Electrical
Monday, July 21, 2025
Blog
Importing multiple PDF pages into AutoCAD
Wednesday, February 19, 2025
See all trending topics and solutions
Related tips and tutorials
Tips
Replace Blocks Using AESWAPBLOCK in AutoCAD Electrical
Tuesday, January 27, 2026
Read
Bookmark
Tips
Save and Restore Your Object Snap Settings with AutoLISP
Thursday, October 9, 2025
Read
Bookmark
Tips
AutoCAD OSMODE System Variable
Monday, August 4, 2025
Read
Bookmark
See all
