I have been having trouble with trying to get the wire to connect straight across.
Any advice would be a great help?
is this a setting issue?
Josh
What is your Drawing Properties set to?
Seems like a imperial/metric units issue...
Thanks for your reply, here is my current setup.
I ran the audit and the main issues were source and destination issues, but a handy tool thanks for showing me that feature.
Josh
Are you working in inches or mm ?
If inches, you must change to this:
If mm, you have a lot of changes to do....
I'm working in mm and I'm having trouble with printing also the template won't scale to the A3 sheet.
Thanks, its a bit of a disaster at the moment because I was playing around with the wire layer colors to get it to print in black.
I appreciate your help.
Josh
Looking at the drawing and your comment about using mm and A3 you might want to make sure you're using IEC libraries and perhaps start with the IEC demo project.
Best regards,
Jeff
