AutoCAD Electrical Forum
Wire not connecting straight
8 REPLIES 8
Message 1 of 9
974 Views, 8 Replies
I have been having trouble with trying to get the wire to connect straight across.
Any advice would be a great help?
is this a setting issue?
Josh
8 REPLIES 8
Message 2 of 9
rhesusminus
What is your Drawing Properties set to?
Seems like a imperial/metric units issue...
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 9
rhesusminus
Normally, you'll get that 45 degree wire if there's already a wire connected to the connection point.
Is there a small piece of wire there?
Run the DWG Audit to remove zero-length wires...
https://knowledge.autodesk.com/support/autocad-electrical/learn-explore/caas/CloudHelp/cloudhelp/202...
Trond Hasse Lie
Ctrl Alt El
Message 4 of 9
in reply to: rhesusminus
Thanks for your reply, here is my current setup.
I ran the audit and the main issues were source and destination issues, but a handy tool thanks for showing me that feature.
Josh
Message 5 of 9
rhesusminus
Are you working in inches or mm ?
If inches, you must change to this:
If mm, you have a lot of changes to do....
Trond Hasse Lie
Ctrl Alt El
Message 6 of 9
I'm working in mm and I'm having trouble with printing also the template won't scale to the A3 sheet.
Message 7 of 9
rhesusminus
Would it be possible for you to attach the DWG here, so I could take a look at it?
Trond Hasse Lie
Ctrl Alt El
Message 8 of 9
Thanks, its a bit of a disaster at the moment because I was playing around with the wire layer colors to get it to print in black.
I appreciate your help.
Josh
Message 9 of 9
JeffatPrimex
Looking at the drawing and your comment about using mm and A3 you might want to make sure you're using IEC libraries and perhaps start with the IEC demo project.
Best regards,
Jeff
