I am using Electrical AutoCAD 2019 and I want to see if I can use a wire annotation format which can produce destination as well as source wire number on the terminal or components.
For example, wire number 215 runs out from A:10 to C:10 so I want to display A:10/215/C:10 at both the terminals A:10 and C:10. Is it even possible?
Pradeep
Solved by rhesusminus. Go to Solution.
Hi Rhesusminus,
Thanks for your response, that a good info you told me. However I am referring to the Point to Point wiring diagram and not a schematic, where I need Source/Destination wire number.
Yes, you are right, I am referring to the Panel wiring. That is where I need the source/wire number/Destination wire labels. The place where I work now, call the Panel wiring as "Point to Point.
Thanks for your input, I guess manipulating the wire numbers to represent the other side, is the only option I have.
I had something like this working a while ago.
I believe if you edit the panel foot print you provide two attributes next to each other which will essentially do what you require. Not in the most ideal manner however if you put in the footprint LOC and WXREF it should display what you want.
LOC WXREF
Shoudl display as
"from location" "wire annotation string"
