I use AutoCAD Electrical to draw schematic circuits....now i am invovlved with a project in which i have to draw a 3D design of the electrical panel drown in AutoCAD Electrical. unfortunatelly AutoCAD Electrical has no ability to draw 3D model of schematic design....What should i do??? is there any software to do this??? a software that has ability to exchange schematic information(symblos....wires and etc) with AutoCAD Electrical???
for 3D you can use inventor, there exist an interface between inventore and electrical. At the moment more für Wire INformations tha for parts but give it a try
Autocad Electrical has the same ability to draw in 3D that plain Autocad has. Electrical is plain ACAD with extra commands and functions added that are designed with electrical requirements in mind. This means that if you know how to do 3D in ACAD, you know how to do 3D in Electrical.
Yes, there are different Autodesk product that are designed for doing 3D assemblies and fancy 3D graphics of which Inventor is one but if you have never used them before, they have a very steep learning curve.
You need to look at what programs you know how to use, the time frame you have been given to do the drawings and any other factors that will impact on your ability to do the work. This will give you an idea on which program to use as well as allowing you to ask for your superior for help at the beginning if you require it.
As a start, have you looked at the workspace you are using. ACADE has a workspace designated for 3D work called 'ACADE & 3D Modelling'.
Regards Brad
Brad Coleman, Electrical Draftsman
Regards Brad
If you just need a 3D layout, with no wiring, AutoCAD Electrical works just fine. If you know how to draw 3D in AutoCAD that is.
You can find an example here: http://forums.autodesk.com/t5/autocad-electrical-ideastation/footprint-geometry-enhancement/idc-p/54...
These are standard AutoCAD blocks, only in 3D, so all standard functionality with AutoCAD Electrical also works.
