AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
What is the benefit of catalog browser?
3 REPLIES 3
198 Views, 3 Replies
Hello Sir/Ma'am,
I am perplexed by the functionality of catalog. As far as I am concerned, using the Lookup can quickly fill up Manufacturer, Catalog, Assembly, etc. But could I also use some sort of table/menu to quickly fill out "Show/Edit Miscellaneous"?
I am expected to create customised Attribute names. But as a result of that, the attributes are recognised as NON-AutoCAD Electrical. The process of filling out those attribute values becomes very tedious and time consuming. Could anyone please suggest me a way to speed it up?
sincerely,
Paul
3 REPLIES 3
rhesusminus
Check the TEXTVALUE field in the catalog database. Should work for you.
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
in reply to: rhesusminus
Hi Trond,
I am not sure how to open the database file associated with the project. I checked the directory path as shown in the screenshot. But the default database file does not have the edited entries from the catalog browser. Please see screenshot.
sincerely,
Paul
rhesusminus
This might be one of those 100 year old bugs in AUtoCAD Electrical. While it SAYS that it's using a give access database, it's actually using a different datbase...
Using Windows Explorer, do a search for default_cat.mdb, in ALL subfolders.. Can you find one with a date/time that seems valid?
Trond Hasse Lie
Ctrl Alt El
Technology Administrators
AutoCAD Beta
