- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
I recently installed AutoCAD Electrical 2016 on Windows 11 (64-bit).
The main issue I’m facing is that the UNDO command has to be manually enabled every time I open a drawing or restart AutoCAD.
It seems the only fix might be a complete uninstall followed by a fresh installation.
My concern is whether I’ll be able to re-activate my permanent license after reinstalling. According to an email from Autodesk:
On March 10, 2025, Autodesk will no longer provide support or activation requests for 2015 and 2016 software versions. At this same time, we will also be retiring the License Transfer Utility.
Can anyone confirm if reinstalling the software would trigger a re-activation process? Or help me with the UNDO command fix?
thanks
