ACADE project-wide utility running script with excessive pause after each iteration
zac42XFK
New Member New Member
zac42XFK
New Member
New Member
Hi, I'd like to run a plot script through the entire project, but there is an excessive pause after the script is complete on a single drawing. The pause can be interrupted with a click in the main window. Sometimes the program freezes. Please help!
JZG
arshdeepsingh404
Hello @zac42XFK
What are you using the run this lisp program project wide?
My preferred way is to create a .scr file to call the LISP file command on multiple drawings. Check out the attached PDF.
You can try adding (command "_.REGENALL") after plot command, This sometimes help to give control back to the AutoCAD UI.
Arshdeep Singh
Electrical Designer & Programmer
C.Tech | CMSE® | Autodesk Expert Elite
LinkedIn
