Trouble with Importing .stp files AutoCad Electrical 2019
volzcaleb
volzcaleb
Hello there. I have been tasked with making a 3D layout of a potential panel enclosure internal layout. The manufacture of the enclosure has listed a 3D .stp file on their website. I saw tutorials for importing .stp files into AutoCad using the IMPORT command.
When I run the command, it prompts for the file name in the command line. When I enter the file name, the import status says by the system variable monitor says it fails.
Any help or advice would be much appreciated! Thank you!
Accepted solutions (3)
rhesusminus
This could be a problem with the STEP file. Do you have a link to this file so that we can have a try?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
volzcaleb
Sure! Here's the file that I got from the manufacturer website. Do I have to have any specific configurations set up for drawing in 3D? I've never used it before, so I am new to the process.
pendean
Community Legend
Community Legend
Worked for me: could it be the convoluted method of step imports is confusing (it's a two step process)?
See attached, is this what you wanted?
volzcaleb
Thanks for that drawing. My mistake was that when the command line would prompt for the file-name, I put in the incorrect path. Thank you both for your help.
