AcePmComServer Error Report
jhartsock
Message 1 of 10
jhartsock
AutoCad Electrical 2023
On start-up, I receive  this error report.
-A software problem has caused AcePmComServer to close unexpectedly-
Acade doesn't crash, but inside a project none of the project functions work. i.e. component surfing, BOM reports, Terminal auto numbering.
I've tried un-installing and re-installing acade 2023
No luck.
Any ideas?
thanks
Replies (9)
Message 2 of 10
mel_stacey
Observer
Observer
i just started having the same problem today. Autocad Electrical 2023.
tired reinstalling also, no luck. sent error report to Autodesk hoping that will help
Message 3 of 10
rbergsG8LD5
I think it was due to a MS office update.
Try reinstalling the Access Database components to see if that fixes the issues
Message 4 of 10
mel_stacey
Observer
Observer
that did the trick.
thank you
Message 5 of 10
jhartsock
With this info I removed "accessdatabaseengine_X64.exe" and re-installed.
Works.
Thanks!
Message 6 of 10
jcrispino3
Wish I saw this sooner!!! Had the same problem.
Message 7 of 10
alds02
Yep, seems like the go-to solution these days always begins with Access Database 2016.
I just used the Repair function, seems to have worked.
Interesting note if anyone at Autodesk is noticing this: the message about AcePmComServer Error always came up *behind* my ACADE window (I don't use full screen). But I could tell it was there, a little bit of the error window extended below the ACADE window.
Message 8 of 10
pharriss95ESF
Which Access components do you mean?
Message 9 of 10
rbergsG8LD5
Message 10 of 10
Richard_Yoerger
Unfortunately, I have accomplished all of the aforementioned solutions (ie Solutions 1-3) and it has not resolved this problem on my AutoCAD Electrical 2024 version of the software. An Autodesk ticket remains open.
