Title blocks attribute setup
Message 1 of 9
This is my first time setting up my own title blocks.  I have two blocks defined (First Sheet and Subsequent Sheets).  The first sheet block has attributes like Dwg#, desc1, desc2, desc3, sheets, Revision, Draft date, Engr. Date, Check Date, etc.  The Subsequent sheets block only has Desc1, Desc2, Desc3, Revision, Sheets, Dwg#.  I can't figure out how to make the subsequent sheet's attributes equal to the title sheet attributes (dwg#, Desc1...).  Online help indicates I should open the dependent block and select the insert field button under default value, but my window only shows "value" and the insert field button isn't there.  What am I doing wrong?   Thanks.
Replies (8)
Message 2 of 9
ramesh.kambang
I am not sure which method you are using. If you are first time creating TB,  I recommend the following tutorial. It is very long but very good. Best of luck.
https://www.youtube.com/watch?v=DYHPg6djwwo&t=26s
Ramesh Kambang
Aerospace System/Design Engineer and eVTOL/EWIS Expert
EASA 21J, UK 21J, MAA DAOS, Certification Specification CS23-29, CS-ANCS, CS-STAN and EVTOL
Please select "Accept Solution" if this post answers your question.
Message 3 of 9
dougmcalexander
My web site includes a step-by-step  guide for creating a drawing template and preparing it for automatic title block update.   If you are going to have multiple drawing templates within the same project, you just need to be sure that  any common attributes are all named the same in each template.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Message 4 of 9
Doug,
Can you point me to the guide?  I would check it out if you can.
Message 5 of 9
ramesh.kambang
http://www.ecadconsultant.com/tips.html
I remember that Mr Doug's tips and tricks really helped me when I started using the acade, highly recommended.
Ramesh Kambang
Message 6 of 9
dougmcalexander
I see that Ramesh answered you.  Thank you Ramesh!  My web site is: [email protected]
Ramesh gave you the direct link to the Tips/Tricks page.
Doug McAlexander
Message 7 of 9
Looks like the guide only works on AutoCAD Electrical.  I am just using LT to do electrical drawings.
Message 8 of 9
pendean
Community Legend
Community Legend
FYI these forums are for the named software in the title, not your line of work or industry.
The AutoCADLT forum is over here https://forums.autodesk.com/t5/autocad-lt/ct-p/2000
Message 9 of 9
Thanks for pointing that out. I’ll post my question over there
