Using ACADE 2024 on windows 10 pro.
Trying to setup a Project Template for everyone to use.
Created a title block with attributes and with the base drawing open, went through the title block setup wizard.
I linked my attributes using the wd_tb method.
Saved the title block drawing.
Created a new drawing, inserted my title block and saved the drawing as a dwt.
Started a new drawing in my project. Used my template for the drawing.
Entered values for the drawing properties. But they won't populate my title block.
When I perform a TB Update, it looks fine to me. See below, from the command line.
What am I doing wrong?
Title Block Edit
Searching BLOCK table for attibute "WD_TB". . . Found. Title block=TitleBlock
Updated DWGNO: --> E00000-00
Updated SHTMAX: --> 01
TITLE (no change)
WHEREUSED (no change)
Updated DWGNO: E00000-00 -->
DRAWN (no change)
DATE (no change)
CHECK (no change)
CADSYS (no change)
Updated SHTMAX: 01 -->
SCALE (no change)
Command:
Solved by jseefdrumr. Go to Solution.
Looks like its updating from nothing to something then back to nothing for DWGNO and SHTMAX.
Have you got these referenced twice in your wdt file?
are those with no change blank?
Yes. But I had to manually update the WD_TB attribute in my title block. Even after going through the Setup again.
Actually, NO. Only some of it. I can't remove the Drawing Values from the title block setup. They keep coming back.
See attached
sorry I'm not so familiar with the WD_TB attribute method. when you say they keep coming back, are you trying to change them to none? can you change them to something else?
I think the wdt file is another method but autocad looks for the wd_TB block first and if it can't find it reverts to wdt
i think the file can be default.wdt and may reside in a support directory
https://help.autodesk.com/view/ACAD_E/2024/ENU/?guid=GUID-62F7B3F0-DE04-4564-A01D-DAED8F34D74B
assume you've seen these
I have but thought it would be easier to share using WD_TB, if we all start with the same template.
your probably not wrong, have you tried deleting / purging your wd_tb attribute definition and creating new?
I have purge. But now every time I re-insert my title block, WD_TB gets placed back in. How do I stop that from happening? aka. Cancel/remove the title block setup.
one of two things,
the wd_tb is in your base drawing, so you keep inserting it
or you need to purge the title block block after deleting it on your drawing
So, the WD_TB attribute isn't getting placed back in, it's embedded in the title block. It's just always been there. Every time you insert that title block, WD_TB will come with it.
If you need that attribute gone, you have to remove it from the source file the title block was made from. Note that since this title block was inserted into a template file as a block, you'll need to use the BEDIT command to remove it from there as well, or use AESWAPBLOCK to change out the old title block (that has a WD_TB attribute) for the new one (which has had WD_TB removed), while inside the template file.
Now, with all that said, after re-reading your post, I'm actually not sure that anyone is seeing this correctly. As I understand it, this is a summary of what happened:
1. you created a title block using WD_TB
2. you started a project
3. you created a new drawing in that project
4. you then filled out all your project and drawing properties
5. you didn't see any of that information reflected in your title block until you ran the title block update command
Is all that correct? If so, the software performed as expected and there is no problem here. Title blocks don't update on-the-fly, ALL title block updates are manually initiated. The sole exception is, if you already have your project and drawing properties set before creating a new drawing in the project, the new drawing will open up with those attributes populated. Test that by creating a second new drawing in your test project. After it opens, all the attributes should be populated, no TB update required.
If my summary isn't correct, can you show us where I got it wrong so we can take a deeper dive into this and see what's going on?
And, if all else fails, you can always post a copy of your template file for us to look at.
I understand the format of the WD_TB attribute now. I originally had some of my attributes assigned to both Project and Drawing properties. That's why they were not showing up. I would populate one but the other would overwrite it.
I think I'm good now.
Good to hear. Post back if the fix doesn't hold.
