AutoCAD Electrical Forum
Title Block Help
2 REPLIES 2
540 Views, 2 Replies
Title Block Help
Im having an issue with the title block I tried to make today. I have made them in the past and they worked. After I make the title block and save it as a .dwt file then try to make a new drawing from the template the created file is not what I expect to see. I get a drawing with title block in it but I see the raw data of the block (ie. can see the wd_tb in the corner and text box names). I used the info here to help me make the title:
blockhttp://www.ecadconsultant.com/tips.html#Template
2 REPLIES 2
testsubject
I see what went wrong.
You need to create a new drawing, insert the titleblock (as a block) into it and then save this as a .dwt.
Then when you create new drawing, the titleblock will act like a block.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
in reply to: testsubject
I completely forgot about that step.
Thank you.
Technology Administrators
AutoCAD Beta
