07:33 AM
Im having an issue with the title block I tried to make today. I have made them in the past and they worked. After I make the title block and save it as a .dwt file then try to make a new drawing from the template the created file is not what I expect to see. I get a drawing with title block in it but I see the raw data of the block (ie. can see the wd_tb in the corner and text box names). I used the info here to help me make the title:
blockhttp://www.ecadconsultant.com/tips.html#Template
Link copied
