Thumbnail missing
Thumbnail missing
Thumbnail missing
When I go to insert a wire connection type or insert an manual footprint, the thumbnails are missing.  I can't figure out where the breakdown is.
I did leave off an important variable about this, I am setup to work off a network.
ChrisPreece
Hi @Anonymous,
Since you're working with files stored on a network, are your schematic libraries paths in Project Properties pointed in the right direction?
If the paths are correct, but you're still not seeing the thumbnails, you might try copying the WD_LOCAL.slb file from C:\Program Files\Autodesk\AutoCAD 20xx\Acade\Support\en-US to the location where your library paths are pointing.  It looks like this solution worked for the user in this forum thread from last year.
If this post answers your question or solves your issue, please click Accept as Solution so others in the community can find it easily.
Chris Preece
Technical Support Specialist
Thank you so much!!!!!  That fixed the problem.
