Connected PLC Address Not Found
I created a PLC block using symbol builder with an existing PLC block that came with AutoCAD Electrical. When I try to retag the components that are connected to the inputs, AutoCAD Electrical does not see the PLC address. Wire numbers recognize the PLC address, but component tags do not.
On a side note, if all of the components are tagged with the PLC address and I change the PLC addresses; it does automatically update all of the component tags and wire numbers.
Any help would be greatly appreciated. Thank you.
2018-11-06 06_17_37-AutoCAD Electrical.png2018-11-06 06_21_37-AutoCAD Electrical.png
I changed the justification and location of the PLC addresses and terminal descriptions on the block, as shown. It works now.2018-11-06 06_37_54-AutoCAD Electrical.png
