Does anyone know if it's possible to create a Terminal table like the one shown in the image or similar?
If it's, how can I fill the spaces with the variables automatically (terminal number, cable, wires, etc.)?
Thank you.
Solved by rhesusminus. Go to Solution.
AutoCAD Electrical includes a table generator that works automatically. It can add drawings to the project, one per terminal strip if preferred, and it inserts a table for each terminal strip. It even fills in the Drawing Description fields with the Location Code and Strip ID. I have attached a sample from the IEC project I created for the AutoCAD Electrical training classes I conduct. You have some degree of control over the appearance of the tables, but they will not appear the same as the tables generated by a competitor's software.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
