Terminal strip jumpers
- Mute
- Permalink
- Report
I'm starting to use terminal strips and I'm having troubles trying to represent jumped connections in a terminal strip.
For exemple on the attached files we can see AutoCad consider wires between TB04-1 and TB04-2 as another connection (terminal number is increased) when in real word we know that this wire is a jumper on the terminal strip.
In a real panel if we have 2 single level terminals with one wire per connection (total 4 wires) , we will bring the COM signal one time to the terminal strip, we put a jumper between the 2 terminal blocks and we can use the other 3 connections to connect 3 more wires.
So how can I indicate to AutoCad that the wire between TB04-1 and TB04-2 is a jumper and should not be taken into account in terminal connections?
Thanks you.
