- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all,
I am having issues with terminal strips. I cannot get them to show and populate the way I am wanting.
1. For multiple terminals jumpered together, I would like a way to fill up all holes in a terminal before adding another terminal. The only way I am seeing to do this is to physically count the numbers of wires going to a terminal and every 4th one add a terminal (since this instance the terminal has 4 holes, a phoenix contact pt4 quatro) With the way it is currently populating the terminal strip there are a lot of gaps and wasted holes adding unnecessary terminals.
2. I am not seeing a way to control the position of terminals in the strip (sequence) without manually moving individual ones up and down. I mean I can arrange them by column in the editor but that does nothing as far as the logical way I would like them. For example on a 3 wire sensor I would like all three wires together so that the wires can be terminated together. Since that is a cable it doesn't work having them spread out on the terminal strip. I also did a project wide terminal resequence and that did nothing.
I will attach my drawings and maybe someone can chime in if I am going about this the completely wrong way on setting up my terminals and give me some direction?
