I am running into an issue with an existing drawing with a table. The table was locked so I unlocked the entire table so I can add a couple of rows. When I edit an existing cell the font changes to something that looks different. In the properties everything looks the same but something is different. I attached screenshots of the cells and the properties. Thanks in advance!
Solved by jseefdrumr. Go to Solution.
I tried having a value of 35 in both cells but it is still saying the contents *VARIES*. I attached another screenshot below to help figure this out. Please let know if there is any more information I can provide. Thanks!
me k
I uploaded the DWG. Also below are more screenshots. I realize I don't have the excel sheet that was originally tied to this drawing.
Yup works perfect!!! Created the new text style and then used Arial Font with 1.0 width and it matches perfect!! Thanks for the help.
