I'm running AutoCAD Electrical 2020 on Windows 10. I tried to select the Duplex Receptacle under JIC: Schematic Symbols - Miscellaneous but the file could not be found. I manually looked up the name HCN1RDUP using Browse and it worked fine.
I just tried to create a new symbol but the Attribute Template - Library Path says <None>.
I found a post that mentions the Causes & Solution but have been unable to locate the ("AT_") DWG files. I thought it was the JIC path but that did not work, any ideas?
Solved by testsubject. Go to Solution.
Check in the Project Properties and verify where the "Library and Icon Menu Paths" point to for all the libraries.
This is where the Symbol Builder gets the file path.
Also, verify that there is a project active. Symbol builder won't work if there is no project.
I switched to a new computer recently, the project I had open at the time was one I started on my old computer so the path is not correct.
