Selection Set Lost On Zoom
I am loosing my selection after I either zoom or pan. I have both PICKFIRST and PICKADD set to 1. I am using AutoCAD Electrical 2017. This was working before I needed to reinstall the software on my machine. Any help is appreciated.
jseefdrumr
I highly doubt this is anything controlled by an AutoCAD variable. I would try doing a Repair first, then another reinstall.
Although, you could try a Reset To Default, but that may not do anything after a fresh install.
Jim
Jim Seefeldt
Electrical Engineering Technician
Wheelie22
Do you mean Zoom and Pan with the mouse buttons ?
Does the command line shows a ^c^c or something else ?
pendean
Community Legend
Community Legend
How are you calling ZOOM and PAN exactly?
Yes with the mouse
danielrayburnpoff
I was having the same problems.  I figured out you need to have SELECTIONOFFSCREEN set to 1 (mine was working, but stopped randomly, and I discovered it had been set to 0 somehow).
use the link below for a list of all other selection related autocad commands
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Au...
