Maybe you could use the local, default_cat.mdb file as the relative one, unique for each user, and set the secondary to point at a common networked location. Be sure not to change the name of the default_cat.mdb. There is a tool that will create a project-specific catalog database. It will automatically create a new database inside of the project folder. The database will contain only the data for the parts used in the project. In order to create the project-specific database the project needs to be pointing to the master catalog database. After the project-specific catalog database is created, the software will use it instead of the master. It always checks the project folder first when it is looking for a catalog database to use.
If, what you are trying to accomplish is to give a project its own catalog database, that is possible. You just place the catalog file you wish to use for that project inside of the project folder and name the file either, default_cat.mdb, or <projectname>_cat.mdb.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
