AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Schematic model out of proportions
3 REPLIES 3
340 Views, 3 Replies
Hey guys, slowly ripping my hair out to this issue...
Trying to start drawing on an A4 sheet using metric, but nothing ever comes at the right size.
First everything was so small i could barely see it on the view, then i did some block update and for sure the outer block on a PLC sized up, but all text inside sits over one another.
Schematic snipSchematic snip
3 REPLIES 3
testsubject
testsubject
It almost looks like you are trying to draw using NFPA (inches) with the settings set to ISO (metric)
I might also recommend placing your titleblock in Paperspace and drawing the schematic in Modelspace. I find it easier this way.
What do these two screens show?
This is a setup for NFPA.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
Bob Hanrahan
Ace User since 1998
in reply to: testsubject
You're probably right.
I can't find a way to switch to metric models
jseefdrumr
jseefdrumr
Switching libraries is done in the Project Properties screen. In the Project Settings tab, at the top, you see all of the paths that ACADE is using to locate things. (This is the same dialog as in your last screenshot.) The paths that says 'NFPA' are the ones that control your Menu Icon libraries. Use the browse button on the right to change them so they point to the library you need.
Jim Seefeldt
Electrical Engineering Technician
Jim Seefeldt
