Schematic Components Won't Show Up on Schematic List or Any Other List
Message 1 of 24
I am using ACAD 2017 and have created a project and copied all of the pages from previous projects to the new project.  Some of the components from one of the pages won't show up on the panel list.  Additionally they won't show up as options when I try to make them Parent to Child level control symbols.  The components were originally generic DVs, I changed the Family to FLT hoping they would pop up when I tried to assign to the FLTs, they do not appear there and do not appear when I select "show all components for all families."  I have tried removing and readding the drawing, refreshing the project, closing and reopening ACADE.  Nothing seems to work.  I believe there is one issue causing both problems.
Replies (23)
Message 2 of 24
rhesusminus
They are not set as "for reference only" ? Can you post one drawing sheet here?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 24
Do you want the DWG?
Message 4 of 24
rhesusminus
Yes please.
Trond Hasse Lie
Ctrl Alt El
Message 5 of 24
Here is the page with the child level sensor, currently labeled FLT on line 510.
Message 6 of 24
TRLitsey
Hi there,
Just a quick note,  You say you redid some of the symbols?  Was this one of them?  It is a child component but it looks like a lost child.  The tag should be the same as the parent, like FLTxx.  FLT will just identify the family type.  Looking at the attributes I see it has TAG2 but I do not see TAG1.  You may want to take another look at this one.  Even if you did not redo this one, it may have been a little odd from the project you copied to begin with.
Good luck
Please mark as a solution if this works for you, kudos are always welcome
Message 7 of 24
rhesusminus
Child symbols won't appear in the BOM unless they have the MFG/CAT/ASSYCODE attributes in them...
Trond Hasse Lie
Ctrl Alt El
Message 8 of 24
The component I want to make parent is on a different page.  If it was on the same page I assume I would be able to pick it with the Parent/Child button. I was able to associate an existing Panel Component with the parent using schematic list in the Edit Component menu.  Now I need to associate the child.
Message 9 of 24
I'm trying to associate the Child with a Parent on another page.
Message 10 of 24
rhesusminus
I edited the CR1 (line 520) to be family "FLT" as well. When editing the child component, and pressing the DRAWING, CR1 appeared in the list.
Trond Hasse Lie
Ctrl Alt El
Message 11 of 24
TRLitsey
Of course I do not have your project but you should be able to open these windows with the Edit Component tool if the project is the active project ....
Screenshot - 6_9_2017 , 1_20_18 PM.pngScreenshot - 6_9_2017 , 1_21_36 PM.png
Message 12 of 24
Yeah, there's something with the associations between drawings I guess.  The only thing that comes up as FLT is the Child.  I was surprised I was able to find the Parent from the panel drawing.
Message 13 of 24
rhesusminus
I'd need the drawing with the parent in it to investigate further... Or the project scratch database...
Trond Hasse Lie
Ctrl Alt El
Message 14 of 24
Here's the one with the parent.  I'm trying to make FLT1 the parent, it was originally DV1 and Family DV
Message 15 of 24
TRLitsey
 ummm .. shouldn't there be an xref attribute on the parent?
Message 16 of 24
rhesusminus
Ahhh. Ok. The parent is a single line symbol (WDTYPE = 1- )
You can't "connect" a schematic child to a parent of another type.
Trond Hasse Lie
Ctrl Alt El
Message 17 of 24
rhesusminus
Nope. XREF isn't required for parent symbols.
Trond Hasse Lie
Ctrl Alt El
Message 18 of 24
TRLitsey
Really?  What would be the point if you can not show the relationship on the drawing?  Honest question, I had not considered that as a possibility.
Message 19 of 24
rhesusminus
There are many examples of parent symbols without children, right? What would you need the XREF attribute for then?
The only _required_ attribute(s) in a symbol, as far as I know, is the TAG-attribute(s).
IF that's in place, and the block name is acccording to the rules, you're good to go.
Trond Hasse Lie
Ctrl Alt El
Message 20 of 24
That's it!  I deleted the "1-" and was able to assign it as a parent.  Now how do I accept that answer?  Also, thank you.
