AutoCAD Electrical Forum
Remove Table Style
4 REPLIES 4
FRFR1512
859 Views, 4 Replies
Remove Table Style
Hi electrical Friends
How can I remove the INCH Table Styles in the Dialog files, only need Metric Tables
4 REPLIES 4
jseefdrumr
in reply to: FRFR1512
Use the PURGE command to remove any unwanted text styles. Keep in mind you can only purge things that aren't currently in use.
Jim Seefeldt
Electrical Engineering Technician
JeffatPrimex
Look for a file in the support path called Tablestyle it holds those default ones.
C:\Users\{user name}\AppData\Roaming\Autodesk\AutoCAD Electrical 2021\R24.0\enu\Support
Best regards,
Jeff
jseefdrumr
in reply to: JeffatPrimex
Jeff's answer is better than mine - I forgot that ACADE will refer to tablestyles.dwg to offer you a list of the styles that are present there. I wouldn't delete this drawing, though, because whenever you add a style from another drawing ACADE will 'push' it to the tablestyles.dwg file. I would just open up this drawing and remove the styles that you don't want to see in your list, using the PURGE command.
Jim Seefeldt
FRFR1512
That is the right solution, it works perfect
