- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi electrical Friends
How can I remove the INCH Table Styles in the Dialog files, only need Metric Tables
Look for a file in the support path called Tablestyle it holds those default ones.
C:\Users\{user name}\AppData\Roaming\Autodesk\AutoCAD Electrical 2021\R24.0\enu\Support
Best regards,
Jeff
That is the right solution, it works perfect
