rectangle , edit dialogue box issue
Hi all
How can I solve this?
When I draw a simple curve, line, circle and then edit (doble click) dialog box is "normal"
but with rectangle is different.
I found similar with open and save as... and was solved with FILEDIA=1
and for edit box?
pendean
Community Legend
Community Legend
What is your QPMODE set to?
pendean , it is to -1    Smiley Frustrated
what is the correct value ?
I have not consciously changed it.
rhesusminus
A Circle and a Line are AutoCAD entities. A rectangle is not an entity but simply a polyline.
If you double-click a polyline the PEDIT command is triggered. This is standard behaviour.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
OK, rhesusminus
thankU
it is extrange, because is not a "tipical" methode to edit objects.
(in general for all programs the same edit box is for all objects  Smiley Very Happy  )
I am learning ACADE for a 1-2 months and think that it includes excesive ACAD tools for a "simple" wire editing program. Not as fast or efficient as it could be but good software.  Smiley Very Happy
rhesusminus
If you change QPMODE to 2, as mentioned by @pendean , the quick properties palette will appear as soon as you SELECT an object. No double-click needed.
This will also give you the quick properties palette when selecting a rectangle.
Trond Hasse Lie
Ctrl Alt El
