"Copy To" feature makes all components children of the original?
gborsosRKDDR
gborsosRKDDR
I'm using ACADE 2024 on Windows 10 pro.
I have a machine with many "Cells" that are identical.  I'm trying to use the "Copy To" right clock command on the drawing name in my project, to save time.  But when I update the tags in the new drawing, it updates the tags in the original as well, to the new tag name.  I need these to be separated.
I've been selecting "Skip" when it asks me to update hoping that helps.  But is there an issue or am I doing something wrong?
rhesusminus
Make sure the different drawing sheets have different installation and/or location codes.
The components in the pages will inherit these in the complete tag , making them unique.
Make sure you have "combined installation/location codes" enabled in the project.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
gborsosRKDDR
Is this the only way.  I am not using these codes.
rhesusminus
Either that, or do a manual on all components but don't update the other pages.
Maybe export to/from Excel will work to help you do this?
Trond Hasse Lie
Ctrl Alt El
gborsosRKDDR
If i "Skip" the update once, will it continue to skip on a Drawing of Project wide update/retag?
gborsosRKDDR
Does "Skip" continually skip that particular component?
rhesusminus
Once it's "skipped", the components aren't related anymore, do you shouldn't see that message again.
I do see many potential problems... You really should consider using installation/location codes.
Trond Hasse Lie
Ctrl Alt El
