Download Manufacturer components into AutoCAD Electrical Library
skelemenZLPUS
Message 1 of 10
skelemenZLPUS
I'm seeking to install Allen Bradley I/O Modules into the 'PLC Parametric Selection' library. Specifically, the 5069 Compact 5000™ I/O modules. These are not included in the current AB AutoCAD library. How to do this?
Replies (9)
Message 2 of 10
ccad2509
this is such and old complaint its no longer a joke
you go to the Eplan data portal and see how much more parts data are in this ACADE
then you go to WSCAD universe and check out their parts database
the you go to see electricals parts database
then what you need to do is find out who the Autodesk manager for ACADE
and tell him your software is a joke
their stock response is manufactures don't want to give them data
your response is why can the above ECAD solutions get the manufactures to supply the data and Autodesk cant
which you wont get a response or a vague non response
you just have to accept the stock answer you can program it your self
Message 3 of 10
galashkina
Message 4 of 10
skelemenZLPUS
Thanks, I pretty much exhausted my search on this and figured out how to add new modules. At the ribbon - Other Tools - PLC Database File Editor - New Modules.
Message 5 of 10
skelemenZLPUS
Thank you. It took a while to find I was able to figure it out in searching through the topics. It's exactly per the link you provided.
Message 6 of 10
rhesusminus
If you are using a REAL CAE program, you'll just do like this:
(view in My Videos)
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 7 of 10
ccad2509
or you can do it like this
or like this
Message 8 of 10
galashkina
@skelemenZLPUS  написал (-а):
I really like the ability to tear the controller image into several parts and change the distance between the terminals. I recently created a programmable relay and divided it into several parts: power supply, RS485, digital and analog inputs and outputs.
Message 9 of 10
rhesusminus
And then, as changes happen, all of the time, put them back together again! 😄
Trond Hasse Lie
Ctrl Alt El
Message 10 of 10
galashkina
No, I added the circuit to the graphical menu.
