AutoCAD Electrical Forum
Publishing ole spreadsheet creates an inverted image ACAD 2022
1 REPLY 1
mark.electricaldesign
904 Views, 1 Reply
When publishing  an Acad electrical 2022 project, the embedded Excel OLE table gets its colours inverted. ie Background is Black and Text is White. This is not good for large BOMs as it uses a lot of ink!
When publishing in 2021 it works correctly.
I've attached a simple project to demonstrate. Any help would be appreciated.
In the attachment are the results from both versions of ACAD.
kind regards
Mark
1 REPLY 1
This is a known issue with 2022.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/OLE-Ta...
Try the "low plot quality" setting...
New version. You get some, you loose some 😉
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Technology Administrators
AutoCAD Beta
