Project Wide Cross-Reference Update does not update XREF Table
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Team,
In need of a little help with this one please;
(Acade 2018) :
When I use the "SCHEMATIC>COMPONENT CROSS-REFERENCE"
Select "PROJECT"
Select "ALL"
Select "OK"
It updates the Parent/Child XREF's OK and the TABLE on the CURRENT OPEN dwg only, but does not update the Tables associated with other drawings Components -(though it physically updates the XREF against the Components in all other Project dwgs -just not their Tables!).
If I manually open each individual dwg (*sigh*), and select
Select "ACTIVE DRAWING"
"OK"
-- It then updates the Table for the Components on the Active dwg fine.
Or/
If I manually select
SCHEMATIC>COMPONENT CROSS-REFERENCE "HIDE/UNHIDE CROSS-REFERENCING"
Select "ALL"
Hit "ENTER"
It sorts out the Xref Tables on the current open Dwg only.
I just cant seem to get it to update 50x dwgs Xref Tables using the PROJECT WIDE methods..
Any ideas? I spent hours on researching a fix for this but to no avail.
I look forward to any suggestions.
Thanks.
-Steve.
