Project Wide Cross-Reference Update does not update XREF Table
Message 1 of 67
Hi Team,
In need of a little help with this one please;
(Acade 2018) :
When I use the "SCHEMATIC>COMPONENT CROSS-REFERENCE"
Select "PROJECT"
Select "ALL"
Select "OK"
It updates the Parent/Child XREF's OK and the TABLE on the CURRENT OPEN dwg only, but does not update the Tables associated with other drawings Components -(though it physically updates the XREF against the Components in all other Project dwgs -just not their Tables!).
If I manually open each individual dwg (*sigh*), and select
Select "ACTIVE DRAWING"
"OK"
-- It then updates the Table for the Components on the Active dwg fine.
Or/
If I manually select
SCHEMATIC>COMPONENT CROSS-REFERENCE "HIDE/UNHIDE CROSS-REFERENCING"
Select "ALL"
Hit "ENTER"
It sorts out the Xref Tables on the current open Dwg only.
I just cant seem to get it to update 50x dwgs Xref Tables using the PROJECT WIDE methods..
Any ideas? I spent hours on researching a fix for this but to no avail.
I look forward to any suggestions.
Thanks.
-Steve.
Replies (66)
Message 61 of 67
moeaung31
I'm using window 10 and Win + Alt + R to start capture video. I have 2 monitors. Not showing dialog box and only see process and result. Yes you right SH column is incorrect for the child. Instead of showing the Sheet for the child, it shows the Sheet value for the drawing the parent is on. I give up!
Message 62 of 67
PatMurnen_Adsk
Moe,
Yes, this issue is separate from yours where nothing was updating. This issue is with table cross-referencing only, and only with the SH field for a child on a different drawing than the parent. The only workaround that I can think of is the script file to open each drawing and run the cross-reference that way.
I logged the issue internally but, anyone who uses this table method and includes the SH field, can open a support case.
Pat
Pat Murnen
Principal Content Developer
Product Development – AutoCAD Product Line Group
Autodesk, Inc.
Message 63 of 67
PatMurnen_Adsk
Steve, were you able to give the script a try? -Pat
Pat Murnen
Autodesk, Inc.
Message 64 of 67
Hi Pat,
No, not yet as I've been off work. I will get on to it sometime soon and come back to you.
Steve.
Message 65 of 67
PatMurnen_Adsk
Steve, sounds good. -Pat
Pat Murnen
Autodesk, Inc.
Message 66 of 67
vapopa
The script (command) work verry well!
Thank you!
Message 67 of 67
henning.berntsen
We have found that if we used the special char # in the source/destination signal code, the source ref can only be updated on one drawing at a time, if we remove the #, the project-wide update started to work again. Strange..
