For what it's worth, here's my opinion...
ACADE is great at creating schematics and panel layouts. It's also possible to do the types of drawings you linked with a little bit of thought.
The standard workflow would be to start a new drawing using a pre-set template which has all the options already set.
Draw the various boxes for the valves and other solenoids or use the included pneumatic/hydraulic symbols.
Insert the various connectors using the 'Insert Connector' tool.
Draw the wires using the 'Insert Wire' tool and add any other schematic symbols as needed.
Number the wires using either the automatic method or the manual editing tool.
Finally you would add the dividing lines on the same layer used for location boxes.
Several things to note however...
The 'Insert Connector' tool allow you to insert Plugs, Jacks and Plugs/Jacks as one single component. You can specify the side the plug is on, the orientation, number of pins, numbering of pins, spacing between pins, connector dimensions and even if the connector is broken and how many pins are in each section.
The automatic wire numbering can be a bit limited in that it follows a set method for numbering wires. you can change some of the behaviour but it is still limited. The automatic numbering however can be set to number the wires with a specific system depending on the wire layer used. For example, you could have a layer set to a specific colour and then change the numbering setup to add a prefix or suffix to indicate the colour.
If you are doing a lot of these drawings and all the solenoids & connectors on them are identical, then it would be easier to spend some time to draw them complete with the shapes for the connector and save them as custom electrical blocks. for example, on the second jpg, I can see 3 differently shaped solenoids that can be made into blocks that would replace 8 solenoids. 4 solenoids with the connector on the right with 5 wire connections, 2 with the connectors on the bottom and 2 with the connector on the top both also with 5 wire connections. It would be faster to insert each one as a schematic block than drawing each square and then adding the connector.
ACADE makes great use of layers with different parts being on different layers. Wires go on special layers, symbols on another and so on. Some of these layers can be changed but most are set to a specific layer. You can add additional layers for the wires for specific functions and then add those layers to the list of wire layers. Layer colours and line types/weight can be set to whatever you like without worrying about any conflicts with layer functions.
Setting up a drawing title block can be tricky but once it's done, you don't have to worry about unless you need to change something in the title block.
Then you add the title block to the template and specify the various formats (Text, Dimension, Table and so on), measurement units and any other settings you need before saving the template. This means when you start a new dwg, everything comes in already set so you can start drawing with no problems.
ACADE uses specific tools to do just about everything. Using the plain ACAD tools is possible but will cause problems with the functionality of ACADE.
I would suggest that you talk to a local Autodesk reseller and ask for a live demo and time to play with a copy of ACADE to see if it will suit your needs. Also ask about training courses as you will need some training to be aware of the common ways to do things and also the common pitfalls and their solutions.
Regards Brad
Brad Coleman, Electrical Draftsman
