PLC Insert Utility
PLC Insert Utility
drew_dewit
PLC Insert Utility
drew_dewit
I am trying to write a custom PLC insert utility. I want to have predefined insertion points for the module based on the number of point and type of card. These are stored in the database ad POINTS and TYPE. It appears that this info is not returned in any of the API calls. Has anyone done something similar? Any suggestions?
rhesusminus
You'll have to get the data manually using wd_oledb_select
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
