How to insert custom wire connection style
nathan.averett
nathan.averett
I created a custom wire connection style following this tutorial: https://knowledge.autodesk.com/support/autocad-electrical/learn-explore/caas/CloudHelp/cloudhelp/201.... I saved the files to my custom library folder. How do I access this style from the symbol builder?
rhesusminus
Try to put the BB*.dwg files in the same location as the attribute template you're using.
Any difference then?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
nathan.averett
Thank you, that was the trick. I was able to point the template file to my custom symbols folder after copying an AT_... template file into it. Once I did that my custom terminals appeared!
