DB9 Connector to Pigtail, Fan In/Out, or???
Fairly new user trying to figure out how to represent a DB9 connector coming from my touchscreen and going to a pigtail. I also want to be able to show the wire colors on the pigtail in case someone needs to reinstall those wires in the field. I thought I should be able to use a Fan In/Out command, but my support rep said that you have to do a Fan In and Fan Out, but that doesn't represent what's going on visually.
You can see in my file that my support rep helped me complete a Fan In & Out so that we can show the wire colors.
I have so many other issues here....
1. Wire # markers are everywhere! The markers in "yellow" I can remove in the "list/edit" attribute drop down. I can't seem to control the wire markers in green without doing an "erase" on the leader and wire #.
2. I don't want to show wire numbers at all, the wires are too small to tag.
3. ACADE is showing the wire colors that I applied for "white" and "red" but not for the "black" wire, why??? How do I get it to show the wire color??
I want to also eliminate the fan out at the connector side.
In all maybe someone out there has a better way showing this properly without completely cheating the system!
Thanks!!
