AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Phoenix Contact I/O Blocks
2 REPLIES 2
2951 Views, 2 Replies
New to AutoCAD Electrical and beginning to flounder...
I am looking for Phonix Contact I/O modules. They are apparently not included in the standard release or maybe they are and I don't know where to look.
I have a few questions. I hope they make sense:
1) Are these something a user would generate from scratch if they were not available from the vendor? Seems like a daunting task. Does it make sense to copy and modify an existing drawing?
2) If they are available from the vendor or from AutoDesk, how would I go about obtaining them and preparing them for my use? Like I said, I'm new to this.
I appreciate any and all help.
2 REPLIES 2
CAD-ICE
Hi there,
you need to get aquinted with the PLC Database editior (located under "Schematic/Other tools" tab (see attached image). In this tool you can copy an existing I/O module preferrably similar to the one you need to create and edit the copied module. Hope this helps you on your way...
Regards, Gary
in reply to: CAD-ICE
Thank you. I will give it a try.
