- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm completely stumped.
I've created a panel footprint/block that I'm exploding on insert into my panel drawing. I'm using the insert from schematic menu to do this. However when exploding and inserting this block is not being properly assigned its default attributes from the "wd_ptag_addattr_comp.dwg" instead of these attributes being assigned the block inserts and the attributes insert off in space away from the block. I'll attach screen shots showing further detail.
The kicker is that I have a near identical footprint/block to this one that was created a while ago from someone else that I based this one off of with only slight modifications and it works flawlessly, the attributes are assigned and the block explodes on insert as it should. Browsing through the text window the only differences I see is that after inserting the block I made the Merged attribute template command that automatically runs immediately executes a _.REDRAW command after it, then comes up with "Error: bad DXF group: nil" then proceeds to automatically close the command.
Like I said I'll include some screen shots in this post detailing what exactly I'm talking about, any help would be massively appreciated!
The working block picture and text from the command is highlighted in yellow in the attached pics, where as the broken block picture and text is highlighted in pink.
