Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Outputting data from a drawing file created in inventor
Arlene_Brown
Arlene_Brown
Hi there,
I am currently using AutoCAD Electrical 2019 and someone has sent me a drawing file which was not created using ACADE. I am looking to output attributes 'TAG' and 'NO' to an excel file. I have tried running the export to spreadsheet command and it outputs the data from the 'TAG' attribute but does not appear to output the data from the 'NO' attribute.  Is it because ACADE is not recognising the name of the 'NO' attribute as the drawing file was created using another program. Can someone please advise how I can export this attribute to excel.
Thanks in advance.
Re
ramesh.kambang
Can you create a table report from that drawing? or you can post dwg file, forum members may help you or give an idea. thanks
Ramesh Kambang
Aerospace System/Design Engineer and eVTOL/EWIS Expert
EASA 21J, UK 21J, MAA DAOS, Certification Specification CS23-29, CS-ANCS, CS-STAN and EVTOL
Please select "Accept Solution" if this post answers your question.
Arlene_Brown
Hi there,
Please see attached drawing file. The attout command is allowing me to output a txt file with the data from the components. I then convert it to an xls file. However I am having to select each individual component in the drawings. Is there a way to select all the components from multiples drawing at once?
Thanks.
ramesh.kambang
when you use this command (ATTOUT), there is way to select all items, see link below for more details. See attached file I have done by selecting all. Not sure about the multiple drawing selection but you can select all items from a drawings.
https://www.youtube.com/watch?v=p-g_00Ltwu8
Ramesh Kambang
