No Conductor Listing
This widget could not be displayed.
I am having an issue with conductor colors not transfering to cable markers as they are inserted into my schematics. See attached images. They do show up in the catalog appropriately but shows "no conductor listing" when I try to change over colors. I know that correct catalog that we have updated is the one my project is pulling from. Any help would be appreciated.
Jacob Miller
Replies (13)
ramesh.kambang
Try this option:
  1. first, insert the multicore cable marker and select the numbers of cores it will bring up Insert/Edit Cable Marker (Parent wire) dialogue box.
  2. click lookup and select the multicore cable catalogue
  3. acade automatically populate the Wire Color/ID with the first conductor color defined in the database.
  4. Click OK
  5. acade automatically populate the rest of the conductor colors per the database color sequence
Ramesh Kambang
Aerospace System/Design Engineer and eVTOL/EWIS Expert
EASA 21J, UK 21J, MAA DAOS, Certification Specification CS23-29, CS-ANCS, CS-STAN and EVTOL
Please select "Accept Solution" if this post answers your question.
Thank you for the reply. It appears the problem is at step 3. After adding the multicore conductor catalogue, it does not populate the Wire Color/ID on the parent.
ramesh.kambang
If the cable marker symbol is already placed, it won't work. You need to start from scratch and define the catalog during cable marker insertion, not after the cable and child are placed.
Ramesh Kambang
This was done with a brand new cable marker I inserting into my drawing. I've also attempted to rebuild the project as well and start another new cable marker insertion with no success.
ramesh.kambang
Are you also using a Secondary Catalog database? Or you may have multiple Catalog Databases. Double-check the path which one is used for your project.
Ramesh Kambang
I have the catalog setup for a single lookup file for my project. I also went through all my support file search paths and the catalog I am using is the only one the shows up.
ramesh.kambang
It works on mine. If the conductor colours are defined in the database correctly, it should populate. Does it allow to add conductor colour manually? Alternative you can post your dwg file, acade members can have a look?
Ramesh Kambang
rhesusminus
Just tried to replicate your settings, and it works fine here. Can you zip up and share the default_cat.mdb so we can have a look at it?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Thank you for the reply. I'm actually dealing with a customer file for this and don't believe I can share this. However, I did test the default_cat for base ACADE and that appears to be working fine so it definitely seems to be a catalog issue. Do you have any ideas I can do to the catalog itself that may fix the issue?
Icemanau
Have you checked that the catalogue entry you are selecting is correct?
Go to Catalogue Lookup and look at the Title Bar just above the catalogue listing (it should be titled Results). At the far right there should be two icons. A Star which is greyed out and a Pencil.
Select the entry you want to use and then click on the pencil.
Now scroll across and make sure the colours are set up correctly in the entry.
Compare them against another entry that you can confirm does work properly.
Regards Brad
Brad Coleman, Electrical Draftsman
rhesusminus
What I've done in some cases, is to use the Migration tool within AutoCAD Electrical to just "copy" the original default_cat.mdb to a new default_cat.mdb. The migration tool WILL process the entries in some way.
So, this is the first thing I'd try.
Trond Hasse Lie
Ctrl Alt El
I appreciate all the help but couldn't get it to work based on the information given here. However, it seems that I have figured a solution to fix this. I had to go into the wd.env environment file and override the location of the catalog parts database path (WD_CAT). It seems I can pull the information from the customers catalog, outside of the color codes, just fine before updating this path. Not sure why this path update is required for color codes to work but this is the solution I have for now.
ramesh.kambang
Unless you modify the catalog location in your working wd.env file, acade uses the default catalog from C:\Users\username\Documents\Acade 2022\AeData\en-US\Catalogs. In acade the wd.env file is the main configuration file which controls the acade.
Ramesh Kambang
