I have a drawing that contains piping from mech/plant 3d or something... How do you delete Proxy images ?
Try the EXPORTTOAUTOCAD command:
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-86C80CA1-F237-4AE6-8A43-2E9CA06A03A8
That didn't appear to work.
I am trying to delete piping left over from a previous project. This is what "Killzombies" show me;
PnP3d Objects created with Plant 3D Piping
It stated they were deleted but select all states the entities/piping is still there.
Posting the drawing as well.
You'll have to open it in Plant 3D and explode them there, to normal solids. Apparently:
Solved: How to convert piping to solid objects or output to STL file? - Autodesk Community - AutoCAD...
Finally found sometime to get back to this.
Yes this was created with Plant 3D.
Just opening it it Plat 3D is the first step.
Most importantly is to add it to a project, then I was able to delete the piping.
Thanks for the help
