AutoCAD Electrical Forum
Multiple catalog attributes
9 REPLIES 9
Message 1 of 10
testsubject
986 Views, 9 Replies
I just spent about 1/2 hour trying to find the list.
I thought that there was a list describing the which attributes where available.
I am aware of (where ##  = 01-99)
MFG##
CAT##
UM##
CNT##
ITEM##
WDBLKNAM##
Does anyone have a list of the rest?
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
9 REPLIES 9
Message 2 of 10
JeffatPrimex
in reply to: testsubject
I came across a list but not in the help and I think you can maybe get and idea from it.
Best regards,
Jeff
Message 3 of 10
testsubject
in reply to: JeffatPrimex
Jeff,
Looks like I was only missing the ASSYCODE and I never use that.
Thanks!
Bob Hanrahan
Ace User since 1998
Message 4 of 10
fotisk
Hi I notice the original question from testsubject and JeffatPrimex reply but i am still having problems.
What I need to do is lets say I got multiple catalogue data and lets say
my 02 has a textvalue with the following RATING10=M12 BK;RATING11=MIR-10M12N;RATING12=EPN350/M12
What kind of attribute i need to create in the symbol editor to refer to these contents ?
I have try RATING0210/RATING210/RATING110/RATING10/RATING1210/RATING10210 but nothing picks up the se contents from 02
Message 5 of 10
JeffatPrimex
in reply to: fotisk
As far as I know there are only 12 ratings available and Texvalues is in the form Rating=Value so your attributes would be Rating1 thru Rating12
Best regards,
Jeff
Message 6 of 10
fotisk
we got a catalogue from 0-99.
lets say 02 from the 99 has an item.
That specific item has a textvalue.
How do i refer to the textvalue of 02 ?
Message 7 of 10
testsubject
As far as I know, the items I listed are the only fields that can be pulled from the database.
And even then, you can only go one deep.
Bob Hanrahan
Ace User since 1998
Message 8 of 10
fotisk
Lets say 1st level is 01.
I can see the CAT01 {displayed as MIR-10M16N}
I can also see level 02 and CAT02
So why I cannot see the respective RATING fields of 02 but i can though see its respective CAT02 field ?
Message 9 of 10
testsubject
Just so we have the "tree" properly called out, the Main part number is level 01 and all Multi-catalog parts (01-99) are level 02 for the nesting of fields.
The Level 01 attributes do not have a number associated with them:
MFG
CAT
UM
CNT
ITEM
WDBLKNAM
ASSYCODE
There are only 7 fields in the data base that are accessible from the Level 02 part:
MFG##
CAT##
UM##
CNT##
ITEM##
WDBLKNAM##
ASSYCODE##
Where ## represents the level 02 multi-catalog part number from (01-99).
As far as I know, there are no other Level 02 fields that can be accessed via the TEXTVALUE field in the Level 01 part.
Also, Level 02 is as deep as the nesting goes. So, if you have a level 02 part that has information in its TEXTVALUE field, this information cannot be pulled into the Level 01 part.
Now, that is not to say that maybe you could write a program (LISP) that might be able to do this but that is way above my expertise.
Bob Hanrahan
Ace User since 1998
Message 10 of 10
fotisk
Makes sense, I am all right with that answer thank you.
