AutoCAD Electrical Forum
Multi-level terminal - terminal with wire number - Block Name: "HT0W02"
13 REPLIES 13
Message 1 of 14
Wheelie22
596 Views, 13 Replies
When I use a normal terminal I can use a multi-level terminal.
But when I use a terminal with wire number it only shows 1 level :
The wire terminal does not use the attributes TERM and LO2TERM :
Terminal with wire number            Normal terminal                           TSE
And if you add another wire it does not show in the attributes :
Can terminals with wire numbers be shown like a normal terminal on a multi-level terminal ?
13 REPLIES 13
Message 2 of 14
galashkina
in reply to: Wheelie22
Message 3 of 14
Wheelie22
in reply to: galashkina
Nice, I wish all commands where documented like this, but...
you use AcadE 2014 and I use 2022 now, and Multi-level terminal works fine with the normal terminal, we use 2 level WDK terminals.
In your example you use the Wire Number Change terminal, did you try it with the Terminal With Wire number ?
Message 4 of 14
galashkina
AutoCAD Electrical 2024
Message 5 of 14
galashkina
1041900000 is a single-level terminal
Message 6 of 14
Wheelie22
No,
Message 7 of 14
galashkina
There is an error in the catalog database. Changes need to be made.
Message 8 of 14
galashkina
Message 9 of 14
Wheelie22
Your terminals are also round !
But why does it work with normal and not wire terminals ?
Message 10 of 14
Wheelie22
I added the LTOTAL and L02WIRENOL+R (like in your help file) and used the Wire Number Change terminal :
And added a L02WIRENO on the terminal for the second terminal number now with a wire terminal :
Wheelie22_2-1707832893176.png  It works !
So update blocks, thanks for the help galashkina.
But can you update the help file, a lot has changed. 😉
Message 11 of 14
galashkina
@Wheelie22  написал (-а):
https://blog.hagerman.com / - this is not my blog.
I read this article once, and it helped me. Now I share it with others.
Message 12 of 14
rhesusminus
And once you get this to work, try Weidmulller 1992220000 😄
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 13 of 14
Wheelie22
in reply to: rhesusminus
Is that a 3 level ?
I found this 20 level block in a AcadE directory :
wd_default_multiterminal.dwg
Message 14 of 14
rhesusminus
It's a three level yes, but the first level contains two separate terminal with a single connection for a wire. The second and third levels have two connection points for wires.
All 3(4) levetid can have saddle jumpers connected also.
Trond Hasse Lie
Ctrl Alt El
