Modify symbol library not working (ACADE 2018)...
This widget could not be displayed.
It seems I can't seem to get the Modify Symbol Library to work.  It locks up on the first drawing at this point....(see pic)
Any ideas?
Replies (23)
rhesusminus
Seems like there's something strange with the text style WD in that symbol. If you remove that first symbol, will it work for the rest of the symbols? Are these all custom symbols?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
No custom symbols at all. All out of the box...Probably of note: I had just installed ACADE 2018 and have only set up the top support path to point to my wd.env file.  No other modifications yet to the 2018 version.
rhesusminus
Ok.
I just saw the "J:\Design Internal" etc. path.
What are your settings for this modification?
Trond Hasse Lie
Ctrl Alt El
rhesusminus
What is the first symbol it opens?
And, aren't these custom symbols, the 82 blocks in the _CI-symbols folder?
Trond Hasse Lie
Ctrl Alt El
Apologies for the late reply.  These are direct copies from the NFPA default symbol library, so at the moment I am running the modify library they are not custom symbols.  Still not sure why it works in ACADE 2017, but not in ACADE 2018.
rhesusminus
What if you rename that folder from "_ci-symbols" to "cisymbols" ?
Trond Hasse Lie
Ctrl Alt El
Currently there are others who rely on that particular folder to maintain its current name.  Once I get a chance to test changing the folder name I'll do so and update.
rhesusminus
Or... Just copy the contents of that folder into another folder.
Trond Hasse Lie
Ctrl Alt El
jesusrperezd
I am still having the same problem, I am running ACADE 2020, any suggestion?
rhesusminus
And, you have the EXACT same problem, with the EXACT same texts on the command line?
f not, maybe fill in a little bit more information.
See the rest of the thread for questions asked.
Trond Hasse Lie
Ctrl Alt El
jesusrperezd
Hi, yes. The problem results when I try to modify the library with a .shx font. If I select a .ttf font the routine runs with success.
The script stops and asks me for modifying some text to vertical or horizontal, when I select any of them it stops.
Opening an AutoCAD 2013/LT 2013 format file.
Regenerating model.
AutoCAD menu utilities loaded.
AutoCAD Electrical menu utilities loaded.
Command:
Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application or Autodesk licensed application.
Command:
Command:
Command:
Command: (COMMAND-S "_.SCRIPT" "C:/Users/JP/AppData/Local/Temp/ace287B.scr")
_.SCRIPT
Enter script file name <C:\users\jp\desktop\a-b\HPB12ML.scr>: C:/Users/JP/AppData/Local/Temp/ace287B.scr nil
Command: _.ZOOM
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: _EXTENTS
Command: wd_scr_msg "========== Drawing 1 of 2 =========="
Command:
Command: wd_sym_wdlib_doit
_.ZOOM
TAG1 height=1.7500
_.style Enter name of text style or [?] <WD_IEC>: WD_IEC
Existing style. Full font name = AMGDT
Specify font name or font filename (for SHX) <AMGDT>: romans.shx Specify height of text or [Annotative] <4.0000>: Specify width factor <0.9000>:
Specify obliquing angle <0>: Display text backwards? [Yes/No] <No>: Display text upside-down? [Yes/No] <No>: Vertical? [Yes/No] <No>: Vertical? [Yes/No] <No>: wd_scr_qsave3
Yes or No, please.
Vertical? [Yes/No] <No>: *Cancel*
"WD_IEC" is now the current text style.
DESC1 height=1.7500
Existing style.
Specify font name or font filename (for SHX) <romans.shx>: romans.shx Specify height of text or [Annotative] <4.0000>: Specify width factor <0.9000>:
DESC2 height=1.7500
Existing style.
DESC3 height=1.7500
Existing style.
CATDESC height=1.7500
Existing style.
XREF height=1.7500
Existing style.
TERM01 height=1.7500
Existing style.
TERM02 height=1.7500
Existing style.
COMMON height=1.7500
Existing style.
Command:
Command:
Command: WD_SYM_WDLIB_DOIT
_.ZOOM
TAG1 height=1.7500
Existing style.
INST height=1.7500
Existing style.
LOC height=1.7500
Existing style.
DESC1 height=1.7500
Existing style.
DESC2 height=1.7500
Existing style.
DESC3 height=1.7500
Existing style.
Existing style.
XREF height=1.7500
Existing style.
Existing style.
Existing style.
Existing style.
rhesusminus
Can you share the two files you have in this folder?
Trond Hasse Lie
Ctrl Alt El
jesusrperezd
sure, I picked them randomly from the library folder.
rhesusminus
Hmm... No, works here. How about a screenshot of your settings?
Trond Hasse Lie
Ctrl Alt El
jesusrperezd
You meant the attached file, right? I added a video so you can see it all.
rhesusminus
I don't have version 2020 installed any longer, and it works for release 2023 where I'm at.
I'm all out of ideas on what this could be.
Trond Hasse Lie
Ctrl Alt El
jesusrperezd
It's ok, thanks for checking this out. I did the modification with the .TTF font, I supposed I got the same results, so this could be an alternative to go with.
rhesusminus
All this being said...
Why would you want to do this?
If you just change the font used by the WD and WD_IEC text styles in your drawings/templates, the symbols will use that font instead.
And, in my opinion, it's always good to use TrueType fonts. Then you don't need to worry about fonts changing when publishing to PDF and font substitution, and you will then get searchable PDFs 🙂
Trond Hasse Lie
Ctrl Alt El
