Modeler DLL's - wrong error
Wheelie22
Message 1 of 19
Wheelie22
Using ACAD-E 2017 and got this error :
But it has nothing to do with this, in this case it is 1 drawing in the active project that causes this.
Erased every thing in the drawing but the block : "WD_M"
So Autodesk can you check this and make a solution or a patch ?
Temporary solution :
Remove the drawing/project from the Project Manager and restart acad-e to continue.
Replies (18)
Message 2 of 19
rhesusminus
If you use the -PURGE command, to purge all Regapps, will that fix it?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 19
Wheelie22
No...  96 registered applications deleted
That is a lot, but the same error.
Message 4 of 19
jseefdrumr
From within the PURGE command, there is a radio button that says 'view items you cannot purge'. Click it and see what it displays.
Could be, there's something on a frozen or off layer, this will help you find it.
Jim
Jim Seefeldt
Electrical Engineering Technician
Message 5 of 19
rhesusminus
You can try to wblock the drawing into a new blank drawing, and see if this removes the problem.
Trond Hasse Lie
Ctrl Alt El
Message 6 of 19
Wheelie22
Can you try to add this DWG into a project ?
I see nothing special in this list :
But you can open the DWG your self and test it ! Smiley Wink
Message 7 of 19
yuvaraj_jaganathan
Please try the workaround given in the following link and reply if it is fixed.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-...
Yuvaraj Jaganathan
Senior QA Analyst
www.autodesk.com
Message 8 of 19
Wheelie22
I did step 1 but no changes
Before i do step 2, can you try this :
- add this drawing to a project
What happens on your PC ?
Erased every thing in the drawing and the block "WD_M" to, the same error
Recoverd the drawing, 1 error, no change
Made an DXF and save it as DWG, add active drawing, error Smiley Frustrated
Here is the DXF with the error in it
Message 9 of 19
Wheelie22
Yes..... thanks, this worked, so audit / recover / purge / DXF dont do the things that WBLOCK does.
Message 10 of 19
rhesusminus
THe problem is that at one point, someone inserted a 3D Solid, surface or something into this drawing.
This marks the drawing as "I need the solid modeler to display this drawing", so when AutoCAD open the drawing, it tries to load the modeler dll's.
Even if you delete those solid/surface objects, the drawing is still marked as "I need the modeler".
So.. There's something wrong with your installation here, with the modeler. The other users here DON'T get any error message, as the modeler is loaded as needed. This is what it look like when I open your drawing:
No error message, just an informational message that the modeles dlls are loaded.
The solution... First, fix you AutoCAD Installation.
And then, use the WBLOCK (as mentioned earlier in this thread) to save the entities in your drawing to a new drawing.
*Hint: Turn on all attributes by setting ATTDISP to ON first. Remember to set it back to "Normal" afterwards.
Trond Hasse Lie
Ctrl Alt El
Message 11 of 19
Wheelie22
If i open a drawing with a solid it works fine
Opening an AutoCAD 2013 format file.
Regenerating model.
Loading Modeler DLLs.
Not on my PC :
But when i add it to the active project it gives the error, i see no logic in this.
Message 12 of 19
rhesusminus
AutoCAD will only load the modeler once per session. If you restart AcadE, Will it try to load the modeler then?
Trond Hasse Lie
Ctrl Alt El
Message 13 of 19
Wheelie22
I see it now
But i dare you, add it to a project, i think you get the error to
Message 14 of 19
Wheelie22
I never told this before, the error happens during this project update, if you open a project or add a drawing :
I did a add active drawing with the DXF version, and no updating and no error.
But saveas DWG and add it to get Updating and the error.
Also made a DXF of the Wblok-ed version (that has no error anymore) and compared them it to the DXF (with the error) by content. There are a lot of differences, if i have the time (not this year) i will check every line Smiley Embarassed
Message 15 of 19
rhesusminus
I added your DWG 'DWG with DLL modeler ERROR.dwg' answering both "yes" and "no" to apply project defaults. No error messages.
Trond Hasse Lie
Ctrl Alt El
Message 16 of 19
Wheelie22
Thanks for testing this.
- delete all files in W temp
- repair
- reinstall
 did not work Smiley Sad
i am gona use the WBLOCK option for easy work around
Message 17 of 19
rhesusminus
Sounds like a plan!
Trond Hasse Lie
Ctrl Alt El
Message 18 of 19
rob.couture
AECLEANDWG solved this problem for me.
Message 19 of 19
tapani.kuikka
This error could be made more informative maybe in the future?, like when opening a Autocad electrical project, there is 700 drawings in the project, and only one of them might have a solid or offending object, but we have no idea which drawing it is.
So the fix right now is to clean up all drawings in the ACADE project , sometimes this needs to be done twice (nested block?). That usually removes this problem, but only for a while until somehow by someone that solid gets copied again back to our electrical project, which drawing? We dont know, so we will clean up the project again...frustrating...
