I don't really have any guesses on what caused your issue. The image you posted showed some extra slashes in a number of paths.
I would suggest resetting the program to Defaults (Windows Start menu > All Programs > Autodesk > AutoCAD Electrical 2016 > Reset Settings to Default. this should take care of settings outside of the project file back to the defaults.
Also, once you have one project set up correctly, anytime you create a new project you can base the settings on that one project. This is an option on the Create New Project dialog box.
Pat Murnen
